Throttle Position Sensor
Re: Throttle Position Sensor
what TPS have you used?
i have one from a CBR600 F i plan on fitting at somepoint,
looking forward to the result DAC,
ps how do you plan on doing the throttle cables there bastard to get in and out without a TPS in the way :s
- DAC
- Bike owned: 89 NC30
Hi, the sensor is from a Vauxhall Vectra I think, £4:99 - new item from EBAY. I tested it functionally as a loose item before going to the trouble of mounting it.
I have always mounted the throttle cables with the carbs lifted up from the ports, and the TPS bracket can be fitted with the carbs in their fully seated position - yes I checked, because I am that sad and thorough!
I would have thought that virtually any type of TPS would be OK, but if in doubt, just wire it up and test it as a loose part while monitoring the Ignitech desktop display.
Regards,
Dave.
Regards,
Dave.
RWB NC30
Great skills Dave - proper job!
How is your brains wired for sorting a working, effective map out?
Ive got a map for the RVF CDI if you wanted to use that as a base, its had hours and hours of dyno time to develop it.
You know ive never thought if doing that, i always struggle lol, i wont anymore have some karma.DAC wrote:Hi, the sensor is from a Vauxhall Vectra I think, £4:99 - new item from EBAY. I tested it functionally as a loose item before going to the trouble of mounting it.
Regards,
Dave.
Edit: wheres the karma gone?
Ive always fitted mine that way, i find it impossible to fit the cables with the carbs in situ
Fiddly as fook but it is possible after you swear at it.Drunkn Munky wrote:Ive always fitted mine that way, i find it impossible to fit the cables with the carbs in situ
I dont know if its posible with the carb tray in situe?
- bikemonkey
Is possible if you reach under the frame, bit fiddly but my hands aren't the biggest.
- DAC
That would be handy, email me & I'll compare it with my initial thoughts if you like.Drunkn Munky wrote:Ive got a map for the RVF CDI if you wanted to use that as a base, its had hours and hours of dyno time to develop it.
Regards,
Dave.
RWB NC30
No problem, PM me your email
