Anyone got a carb balancer?
- royster81
Re: Anyone got a carb balancer?
I did my bikes the same as Ricky, but without the marigolds. And a long 7mm socket so you have something good to grip onto.
I bought flexi screwdrivers etc but the carbs are that sensitive even the slightest pressure on the adjusters made the bike rev
royster81 wrote:I did my bikes the same as Ricky, but without the marigolds. And a long 7mm socket so you have something good to grip onto.
I did mine without the marigolds
I tell a wee fib...I have never used the gauges..and it sounds like a right ballache! How do you access it if you run a carb tray?
- royster81
Balance without, then refit tray
but does that not throw the delicate balance out -if you don't get the same seal and the carbs get twisted and so on?
I thought that it was quite delicate..
Concrete Jungle
- Bike owned: NC 35
You can borrow mine, if I ever get it back from the lad on here I loaned it to.
- bikemonkey
Thankyou, will take you up on that if you get it backConcrete Jungle wrote:You can borrow mine, if I ever get it back from the lad on here I loaned it to.
Wasn't me...so name and shame!
- laminator
- Bike owned: 2tk,NC30, YB7
Hi, I've got a Morgan carb tune you can borrow. Don't think I've got the adapters for the NC though. Although there are some bits in the bag side pocket. It's in Derby so close to you. I'm in Glasgow until Friday but there's someone at workshop from 8 until 5ish. I'll be back Friday night. I've got a 90 deg screwdriver as well. Let me know if you want to borrow it.
- bikemonkey
That would be brilliant. I don't need it immediately so if you could possibly check the adapters you do have whenever you can, might be in luck with the right onelaminator wrote:Hi, I've got a Morgan carb tune you can borrow. Don't think I've got the adapters for the NC though. Although there are some bits in the bag side pocket. It's in Derby so close to you. I'm in Glasgow until Friday but there's someone at workshop from 8 until 5ish. I'll be back Friday night. I've got a 90 deg screwdriver as well. Let me know if you want to borrow it.
Thanks in advance
Its how I do it also as you knowporndoguk wrote:its and m5 thread for the vacuum points, sod fancy screwdrivers if you got small enough hands use a marigolds glove and a 7mm socket and use your fingers, thats how i do it its fiddly but doable
