David silver part numbers for hrc overflow bottle?
Re: David silver part numbers for hrc overflow bottle?
No idea on the parts number but I will check through some parts books this evening and see if I can find it.
Personally though I would just use any bottle and some cheap tubing, becuase it is supplied by HRC won't make any difference.
This is the ticket
Many people on here use fruitshoot or similar bottles.
I will see what I can dig up anyway incase you must have the named one
This is the ticket
- thunderace
- Bike owned: R6, YZF600R
Is that a Gin bottle Neo?
I use a cow & gate babys first milk bottles however ive just come accross boots baby water with a hint of xxxxxxxx there only about a £1 and there thick clear plastic 150ml bottle just the ticket.
Hoses go cloudy pretty quick and i understand yoir racing however youll need to drain after everyrace.
Why not contact rick oliver for some brembo hose its black but wont leak
Good eyethunderace wrote:Is that a Gin bottle Neo?
- xivlia
- Bike owned: Ducati 749 D
is that gin bottle glass? if so, wouldnt it shatter at high speeds from vibration? it looks like glass to me
Don't start getting any ideas.
It's a small plastic Tanqueray bottle, most commonly found at airports etc thats been nicely finished off to fit pipes to it.
- speedy231278
A friend of mine used a 500ml coke bottle on his Blackbird..
http://www.boots.com/en/Boots-baby-wate ... l_1263709/
£0.75p :D
plus when the label is removed there are 3 convienient groves which a cable tie would fit within without the bottle being over tightened.
£0.75p :D
