Clutch Lever Reach too Long
Re: Clutch Lever Reach too Long
In
Out
Shake it all about
Out
Shake it all about
HI try ebay item 330803667252 hope that helps see if breaker will include a clutch switch connector will measure the span on my bike so u can compare with the other levers shown reg c
- speedy231278
I'm sure that my standard lever is one heck of a lot closer to the bar when in and out than that. I have mine set up so there's not a massive amount of movement required, but that looks more like a switch! I'll never forget the time I got the bike back after a service and the play had been adjusted rather badly. I think in and out were about three fag papers apart. Looked like a right wally when I kept stalling trying to get the bike away from the workshop until I adjusted the cable.... lol
- missis sumner
- Bike owned: NC30 + Teapot
I had the same problems with my NC30 when I first got it. I replaced the standard lever with a shorter Titax adjustable, but it really didn't make an awful lot of difference. I think I've just got used to it now.
Goodevening my lever appears to be about 50mm from bar measured the same way as above photos at its min set up thx craig.
Cant you just slacken the cable off a bit?
- Bike owned: NC30 91 jap import model
Hi, thank you but i've found one Blacks. The lever and bracket off a ZZR600 apparently fits so going to try one of those!
you could just buy stock vfr750/800 levers that come with a span adjuster
