Intermitant Problem NC30
leef82
Bike owned: vfr400 nc30
Re: Intermitant Problem NC30
Post by leef82 »
have a look at the reg/ rec and see if its burnt or melted, when mine was on its way out it use to die when i opened it up to over take, then i had to wait on the side of the road for 15 mins or so untill it started again then hour later it would happen all again, where abouts in lincolnshire are you?
AndyJak
Bike owned: ZXR400, NC30, ZX10-R
Post by AndyJak »
leef82 wrote:have a look at the reg/ rec and see if its burnt or melted, when mine was on its way out it use to die when i opened it up to over take, then i had to wait on the side of the road for 15 mins or so untill it started again then hour later it would happen all again, where abouts in lincolnshire are you?
I have looked at the reg. Seems ok but gets damn hot. I am in Sleaford area mate.
regards
Andy
leef82
Post by leef82 »
if you can get the bike over to boston you can try my cdi if you like, i had a look in the the loft to see if i had a spare but no luck,
AndyJak
Post by AndyJak »
leef82 wrote:if you can get the bike over to boston you can try my cdi if you like, i had a look in the the loft to see if i had a spare but no luck,
That's a great offer mate. But I don't think the bike will get to Boston. I have just tried it again. Did a mile before I just opened it up a little and it went again. Only just made it back home. I suppose I'll just have to buy a CDI unit in the hope it will be that.
Thanks again and maybe see you on the road.
:peace:
Andy
leef82
Post by leef82 »
ask in the parts section im sure some one on here will have a spare, but tbh it sounds like the reg rec
lee
AndyJak
Post by AndyJak »
leef82 wrote:ask in the parts section im sure some one on here will have a spare, but tbh it sounds like the reg rec
lee
Why does it sound like the reg/rectifier? What are the symptoms of that problem?
leef82
Post by leef82 »
theres quite a few symtoms i think, but the ones i had were : it would run ok ,every now again above 6k it would have a lack of power and run rougth until it would completly die , then it would not start at all for about 15 mins , it was just killing the battery, once it started again it would be ok for about an hour but got more frequent, it is a common problem on these nc30's ,it could be something completly different, ive had two go wrong,
AndyJak
Post by AndyJak »
leef82 wrote:theres quite a few symtoms i think, but the ones i had were : it would run ok ,every now again above 6k it would have a lack of power and run rougth until it would completly die , then it would not start at all for about 15 mins , it was just killing the battery, once it started again it would be ok for about an hour but got more frequent, it is a common problem on these nc30's ,it could be something completly different, ive had two go wrong,
But my battery seems very strong. In fact it's turning over lovely right now but the damn thing won't start at all now. Plenty of juice in the battery.
Are you saying a new reg'rectifier fixed your similar running problems? I am at a loss as to what is wrong with my bike.
Andy
I got one you can borrow but I think you to atleast check the reg is giving the right volts and the battery isn't goosed first. Don't think I've ever heard of a cdi going.
leef82
Post by leef82 »
Yeah if your battery is ok prob ain't the reg/ reg, how about coils or gummed up carbs?
