NC30 possible carb air leak locations
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Re: NC30 possible carb air leak locations
Post by krisztian_andre »
I made a video of the idle and it isn't too bad but it becomes worse when the bike gets hot in city traffic:
http://www.youtube.com/watch?v=xWPNfLjx ... page#t=93s
What do you think?
bikemonkey
Post by bikemonkey »
Sounds a little like mine, but much more noticeable.
I however know my valve clearances need doing (I know it needs doing, winter time won't be long knowing England...)
Plus my carb restrictors for my 33bhp license and the fact I haven't re-jetted to suit might be a contributing factor.
How long ago were yours done?
krisztian_andre
bikemonkey wrote:Sounds a little like mine, but much more noticeable.
A week ago.
J.B.
Post by J.B. »
Kris,
I still think the most likely cause of the air leak is the O rings in the mixture adjustment. The ones I sourced locally are: 1 mm CS X 3.00 mm i.d. This is slightly smaller CS and slightly larger i.d. than OEM. So, they're a loose fit on the slow jets, too loose IMO and being a tad thinner CS I suspect they do not seal as well.
I suggest you either:
1/ pay the big money and get the OEM NC30 gasket sets (I already know you're not gonna go this route LOL)
2/ check if the OEM O rings from some of the pre-FI local 100 cc Hondas are a direct replacement (i.e. '08 Click, Wave etc). They all use Keihin carbies so there's a high likelihood of an exact match.
3/ try and source Nitrile O rings in the exact OEM size: many, many to choose from here:
http://www.rubberstore.com/catalog/as56 ... 39_43.html
Hopefully someone who knows the exact dimensions of the OEM o rings will chime in and assist.
Cheers,
Jimmy
Since you dont know you have an air-leak then i`d forget about the airleak idea for now.
It could be an air leak but sort the electrical out first.
Hanging revs can also be caused by a lean mixture, try backing the pilot screws out another turn and see how that affects the return to idle.
J.B.
Post by J.B. »
He doesn't know he has an electrical problem either.
krisztian_andre
J.B. wrote:Kris,
Cheers,
Jimmy
The idea is that if I find the o-ring measurements then nobody will ever have to pay 60 or 80 GBP just to get four new o-rings for their pilot screws.
Keihin part number: 16075-KG8-9010 pilot screw o-ring CS1.2mm ID2.7mm
fits the description.
JB, I lost the paper with the washer's dimension, do you still have it?
J.B.
Post by J.B. »
That is pretty much exactly what I measured the OEM o rings to be, yes.
The washers ... I don't have any anymore because all my spares are now in your carburetors but Rick O told me he measured them at: 5 mm o.d. x 3 mm i.d. x .5 mm thick.
JB
krisztian_andre wrote:
J.B. wrote:Kris,
Cheers,
Jimmy
