Limp home mode?
Re: Limp home mode?
How's ti rev up in netural and first / second etc.bikemonkey wrote:Well I got home at 60mph, just had to sit in the left lane behind lorries......
Think I'll bridge the wires instead of modding the CDI. Just need to get my hands on the stuff now.
It'll only rev upto 5500rpm in any gear if it is that proble,
If it's not reving above 5500rpm in any gear / netural then it could be the speed restriciton cutting in.
The connector is the one one coming from the speedo, this runs to the ignition box.. it's strange it'd come loose.
You should have connection from there to the ignition box, if it's not that then something else.
- bikemonkey
Re: Limp home mode?
It revs normally in neutral first and second, but as soon as I hit third it cuts the spark and the bikes power delivery makes it jump about like a rocking horse. I'll double check the wiring later tonight, but it was all plugged in when I checked last night.
Re: Limp home mode?
It really sounds like theres something else wrong with your bike then.bikemonkey wrote:It revs normally in neutral first and second, but as soon as I hit third it cuts the spark and the bikes power delivery makes it jump about like a rocking horse. I'll double check the wiring later tonight, but it was all plugged in when I checked last night.
From my memory (perhaps I could be wrong! best to get confrimation) but If you disconnect the speedo sensor unit it wont rev over 5500 in any gear.
Re: Limp home mode?
Hmm..strange one then - not sure the bike knows what gear it is in so how can it affect the CDI?
I'd try to disconnect the speedo to force it to fail in N 1 and 2. Or not....
- bikemonkey
Re: Limp home mode?
Unplugged the speedo, let me rev past 6k in neutral oddly enough.
- bikemonkey
Re: Limp home mode?
In neutral may I add
- bikemonkey
Re: Limp home mode?
Went out for a quick ride, and the bike revs fine in 1st 2nd 3rd and neutral with the speedo plugged in, but as soon as I hit 4th it bogs me right down to 6k revs.
Will try again tomorrow with it unplugged. Should have done that tonight but for some reason I plugged the thing back in.......
twist&go
Re: Limp home mode?
when your riding the bike does it start jerking almost like its pulsing on and off?
if it is check the block connector and wires to the CDI had a fault with mine like that turned out a wire to the CDI had started to fray. just a thought
- bikemonkey
Re: Limp home mode?
Yeah it behaves like that when I get into 4th at 6k, like its a bucking bronco or something. I'll check that too, thankstwist&go wrote:when your riding the bike does it start jerking almost like its pulsing on and off?
- bikemonkey
Re: Limp home mode?
Well I disconnected the speedo plug and it's doing the same thing.
Letting me rev to about 10k in first and second (only 10k due to restrictor washers), then bogging me down about 8k in third and taking me down to 5.5k for the rest of the gears.
Also checked the CDI wiring and it all looks in good nick.
Shall do the resistor mod when my brother goes back to school tomorrow and makes me up one.
If that doesn't work I'll be out of ideas :/
