Gear change bit stiff and hard to find neutral
wambam87
Re: Gear change bit stiff and hard to find neutral
Post by wambam87 »
Sounds like a plan , were would i get the front fork kit from ?
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
rick oliver , here is his latest price guide , all order info in the list
viewtopic.php?f=22&t=26174
Deviants AM/PM build
viewtopic.php?f=62&t=27307
wambam87
Post by wambam87 »
Awsome thanks , How hard / easy are the front shocks to do ?
Deviant400
fairly simple , with the bike on a rear stand jack up the front end under the front pipes, remove wheel then loosen fork tops, loosen yokes pull forks out, unscrew fork tops and the oil drain bolt at the bottom just below caliper mounts, pump out old oil , remove standard springs replace with new fill with the oil supplied in the kit with the syringe that also come with the kit , dead easy mate no real hassle at all , comes with instructions anyway , grab a haynes too as it comes in handy when your sat on the bog havin a dump
Mavirick
Bike owned: NC35
Post by Mavirick »
Lets see some pics
amaechizzle
Bike owned: NC35
Post by amaechizzle »
Deviant400 wrote:grab a haynes too as it comes in handy when your sat on the bog havin a dump
Mavirick wrote:Lets see some pics
Now fellas...
Thats for the general chat section.
