3TJ swingarm bearings
				Clanky
- Bike owned: FZR 400 3EN1, FZR 600 3HE
				rockTJ
Re: 3TJ swingarm bearings
The bearings in that link are not shell type needle roller bearings?????
The only one listed as having a 17mm shaft size has an outer diameter of 35mm, well over the 24mm needed.
Maybe special order with them
				Clanky
Hi Chris,
The bearings I listed were for the swingarm relay in case you wanted to replace the bearings in that while you were doing those in the swingarm. Didn't mean to cause any confusion
Try these blokes for bearings:
http://shop.marksman-ind.com/motorcycle ... uk-2-c.asp
				rockTJ
Ah ok.  I'm trying to save as much as possible including old bearings.  I will check and liberally regrease as I rebuild it.  I dont think it will take long to get the frame/forks built up but there on in may take a while  Both wheels will need powder coating which means more bearing shenanigans!
Chris
						Chris
