Page 2 of 2
Re: Front wheel knocking,, what can it be?
Posted: Thu Mar 15, 2012 6:17 pm
by thunderace
DK-Tandy wrote:the knocking stops under braking, whether it stupidly light braking or heavy braking
It's either loose calipers/pads or a bearing issue IMO then.
Posted: Thu Mar 15, 2012 6:21 pm
by Wozza
If you hold the front brake on and rock the bike back and forwards do you hear the knocking? If so check for play between the brake disc rotors and carriers.
Posted: Fri Mar 16, 2012 12:18 pm
by tanuki
Posted: Fri Mar 16, 2012 12:42 pm
by angry_rob
As stated before check for play in the bearings and headstock. Also I had a similar problem not too long ago, which was because of a combination of sticking brakes and warped brake discs. I've rebuilt the calipers and there's no clicking any more (not to mention the brakes feel 10x better) even with the same warped discs.
Posted: Fri Mar 16, 2012 1:52 pm
by vr46
Have you got a front wheel stand? can you hear the clicking if you spin the wheel by hand?
Posted: Sun Mar 18, 2012 7:26 pm
by amorti
Wozza wrote:If you hold the front brake on and rock the bike back and forwards do you hear the knocking? If so check for play between the brake disc rotors and carriers.
My t595 did this, I thought the steering bearings were no good but in fact there was just play on the disc bobbins.
Also check for loose brake pads, and the classic mudguard brackets.
I've also seen real stupid shit like a stone in one of the brake disc drillings making a noise as it went round.
