Front wheel knocking,, what can it be?
thunderace
Bike owned: R6, YZF600R
Re: Front wheel knocking,, what can it be?
Post by thunderace »
DK-Tandy wrote:the knocking stops under braking, whether it stupidly light braking or heavy braking
It's either loose calipers/pads or a bearing issue IMO then.
Wozza
Post by Wozza »
If you hold the front brake on and rock the bike back and forwards do you hear the knocking? If so check for play between the brake disc rotors and carriers.
tanuki
Post by tanuki »
tanuki wrote:headstock?
angry_rob
Post by angry_rob »
As stated before check for play in the bearings and headstock. Also I had a similar problem not too long ago, which was because of a combination of sticking brakes and warped brake discs. I've rebuilt the calipers and there's no clicking any more (not to mention the brakes feel 10x better) even with the same warped discs.
vr46
Bike owned: All sorts
Post by vr46 »
Have you got a front wheel stand? can you hear the clicking if you spin the wheel by hand?
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
Wozza wrote:If you hold the front brake on and rock the bike back and forwards do you hear the knocking? If so check for play between the brake disc rotors and carriers.
My t595 did this, I thought the steering bearings were no good but in fact there was just play on the disc bobbins.
Also check for loose brake pads, and the classic mudguard brackets.
I've also seen real stupid shit like a stone in one of the brake disc drillings making a noise as it went round.
