Page 2 of 5
Re: sticky yoke or steering?
Posted: Fri Feb 17, 2012 1:26 pm
by thunderace
You may also want to check that the forks are straight and both the same uncompressed length if it's wandering to one side.
Posted: Fri Feb 17, 2012 5:59 pm
by xivlia
good idea, il need to check that too.
Posted: Mon Feb 20, 2012 6:57 pm
by xivlia
okay i went to my dealer today, and the mechanic checked it out and he said that the steering stem would not bend by just dropping the bike going at 5 mph... he reckons that the bearings got rusty and salty. because my bike was getting soaked with rain for about 2 months as it was staying outside, and i hadnt used it for 2 months. so he said some rain and salt probably got inside the bearings and that the salt has probably eaten through the bearing and left it with no grease on it, hence why it is sticking.
Posted: Tue Feb 21, 2012 7:30 pm
by xivlia
do you think i can maybe put some oil down in from the side gaps for the steering bearings? do you think thatl make some difference or act as a temporary fix? if so, i shall do this and then dismantle the whole thing next month on my pay day.
Posted: Wed Feb 22, 2012 2:12 pm
xivlia wrote:do you think i can maybe put some oil down in from the side gaps for the steering bearings? do you think thatl make some difference or act as a temporary fix? if so, i shall do this and then dismantle the whole thing next month on my pay day.
Are you serious?
You are a danger on the road... it's like saying the brakes are faulty so can I bodge them.
If you can't steer properly, as you said before you risk crashing, and hurting not only yourself but other people.
CHECK the bearings first, they are not difficult to get to.
Remove the top yolk first and inspect the upper bearing.. then lift the front of the bike up, remove the wheel and forks (no need to remove brake lines, just unbolt the calipers and tie them up) and drop the yokes completely.
The bearings can be had cheap as a set.
If they are dirty, rusty then they are most likely scrap so just throw them away, it's not worth messing with.
If they are just stiff, clean them out with some kerosene (parrafin) and see if they still roll freely, ANY stiffness or pitting then bin them.
If they are ok, clean them thorougly and grease them up and put them back in.. taper roller bearings can be had cheap off wemoto et al and are probably the way to go.. occasional rain shouldn't affect them, my bikes been outisde 20 years and is fine.
Posted: Wed Feb 22, 2012 8:03 pm
by xivlia
yeah i shall do that, i jsut dont know how im going to lift the front of the bike. i no longer have access to the bike jack.. all i have is a rear paddock stand. any suggestions?
Posted: Wed Feb 22, 2012 8:43 pm
by thunderace
Ratchet strap around a roof beam looped around just behind the headstock.
Posted: Wed Feb 22, 2012 8:48 pm
by xivlia
i have no access to a roof unfortunately. the bike is standing outside...
Posted: Wed Feb 22, 2012 9:20 pm
you're going to have to pay for it then... either buy a jack or someone else ot do the work.
I do quite like you mate, you are alright...but you are a liability and you need to not be taking the piss with dangerous bodges, a dangerous bike or doing stuff half assed.
You have a responsibility to yourself and your family to make sure you are riding a bike that is safe.
There are 400GB users in your end of the world - I am sure that if you asked them and provided beer, tea or biscuits that they would allow you to use their garage or offer you a hand.
Bring it to my house..take you 6hrs. You can get some work on it, have a beer and then get some kip, get up, finish fixing it and ride home...
Posted: Wed Feb 22, 2012 10:20 pm
by xivlia
yes u are right, i think there is someone based in nairn which is 15 mins away from where i am with a vfr 400 nc30, but i cannot remember his name. maybe he might have a garage or a jack to lift up the bikes front.
