spark plug coverd in gunk and small stones?
porndoguk
Re: spark plug coverd in gunk and small stones?
Post by porndoguk »
in addition, the helpfull less ranty bit,
Try useing a small mirror and a torch to see whats in the rocker cover, use a mobile phone on MACRO camera mode, and take a load of pics to get an idea of whats going on what ammout of dirt your dealling with,
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Drunkn Munky wrote: even so it shouldnt be like that and id be pulling the head even if its just the clean the crap out.
oooh er missus.
Surely that has been dropped on the floor or in a sandpit, or you didnt have the correct honda spark plug tool and its been rolling around the plug recess while trying to get a grip of the plug.
if not then dont pile one more penny into that bike on anything else, and hunt for an engine from someone on here who will sell you a decent engine.
Is the drain hole in the head blocked ? and the plug recess full of shit ? i mean you cant do it now and run the risk of half the road dropping into the cylinder resulting in a buggered motor. if the drain hole is clear then you have problems.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
go get a better camera and take some quality pictures on macro setting, dont fuck around with some camera phone, quality images will help diagnose this and what the material is.
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
i understand what you mean, but i can assure you, ive tightened these in properly. i didnt use a torque wrench. but i tightened them pretty much as tight as it can get, i am still confused how it can end up like this as i know i had cleaned them properly.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
oh dear, stop right now. you are not supposed to tighten them as far as you can, finger tight then a nip.
we need to see a picture with the rads removed in some proper light down the spark plug hole with a proper camera. likewise with the plug that came out, and the new one with all that shit on it. dont guess at this, if its come from a blocked drain hole then its not the end of the world, if it metal matter and shards then your in to a head removal at the very least. before you start having a go, just stop and think before diving in.
we want to help and advise accordingly, but if you dont listen or rush then its only you who will lose out
Delboy
Post by Delboy »
That couldnt of come out like that, too much crud on the thread, the plug must of rattled around loose collecting the crud before you managed to pull it out clear of the cylinder.
Even a stripped thread would have metalic contact showing.
missis sumner
Bike owned: NC30 + Teapot
Post by missis sumner »
vfrderek wrote:That couldnt of come out like that, too much crud on the thread, the plug must of rattled around loose collecting the crud before you managed to pull it out clear of the cylinder.
This, surely?
Did you clean the bike after you dropped it?
porndoguk
Post by porndoguk »
This, surely?
dropped, what happened did i miss something, did this get dropped into a canal?
Delboy
Post by Delboy »
No, I believe it was a sand pit :roll:
porndoguk
Post by porndoguk »
vfrderek wrote:No, I believe it was a MONEY pit :roll:
edited that for you
