what oil for forks
leerc
Re: what oil for forks
Post by leerc »
thanks for the help chaps,yeah the pic of the later forks is the same as mine
are they better than the older forks?
tbh i never give it a thought i just seen them n thought for that price ill give it a bash
Le_Blur
Bike owned: 1990 NC30
Post by Le_Blur »
Yeah, as well as having preload adjustment, the later forks have cartridge style internals instead of the old rod damper system.
Bike owned: VFR400
Post by magg »
Believe OEM fork oil for cartridge NC30 forks to be Showa SS-7 which has an ISO viscosity index of 16. ISO index is considered to be a much better indicator than SAE weight. SAE weight for fork oils can be all over the place, one manufacturer's SAE 15 can be the equivalent of SAE 20 for another manufacturer.
999Gomerz
Bike owned: Hondas, Ducati, Suzuki, Vespa
Post by 999Gomerz »
Honda Ultra Cushion Oil 5W :grin:
Le_Blur
Post by Le_Blur »
I forgot to mention, oil level for the newer forks is 122mm (measured in the way described previously).
leerc
Post by leerc »
are they dismantled in the same way?
magg wrote:Believe OEM fork oil for cartridge NC30 forks to be Showa SS-7 which has an ISO viscosity index of 16. ISO index is considered to be a much better indicator than SAE weight. SAE weight for fork oils can be all over the place, one manufacturer's SAE 15 can be the equivalent of SAE 20 for another manufacturer.
999Gomerz wrote:Honda Ultra Cushion Oil 5W :grin:
The standard forks originally had a sticker on them that says Honda Ultra Cushion Oil number 10
Which is SAE 10, I have a can of it not 5 feet from me.
Don't use anything thicker or thicker unless you mod the fork valves, it'll do strange things to the rebound and dampening
leerc
Post by leerc »
im confused now,been digging around n a few threads are says 450ml of oil
Le_Blur
Post by Le_Blur »
It may be one and the same. The Haynes manual specifies it as an oil level measured from the top of the stanction under full compression. You're simply quoting a volume of oil to put in. Since the air gap is the crucial factor, it's probably safer to measure that rather than just put a set amount in since you're never sure if you've completely drained the forks.
leerc
Post by leerc »
http://www.youtube.com/watch?v=DIizmZ_OpSY
are they dismantled/reassembled the same way as this ?
