How do you.....
iDemonix
Bike owned: '92 NC30
Re: How do you.....
Post by iDemonix »
But are they there to stop the bike falling back? Or do they have some other use?
philfingers
Bike owned: NC30 Type 7
Re: How do you.....
Post by philfingers »
no it's there to support the bike when i remove the Abba stand, as the Abba use the swingarm pivot you can't use the Abba when you want to pull the swingarm spindle out.
dx400r
Re: How do you.....
Post by dx400r »
Im rebuilding the race bike atm so maybe I should make a guide....but off the top of my head heres how I would do it.
1. Get bike in air and make sure its secure.
2. Remove wheel
3 Remove Rear bodywork
4. Remove Tank
5. Disconnect two spades from Rear Coil
6. Unbolt battery earth lead
7. Remove battery
8. Remove bolt securing undertray to frame (LHS of bike looking at it with nose facing forward)
9. Free the rear brake line from its retaining hoop on the undertray
10. (optional easy life task) Remove rear section of exhaust system
11. Unbolt Exhuast Can bracket
12. Remove the two lower bolts from attaching subframe to bike and loosen the top two
13. Flip subframe upwards so it points up in the air and tighten up bolts to keep it there
14. Remove supension linkages enough to get to bolt holding bottom of shock and get it undone
15. Undo suspension top mount and pull shock free
philfingers
Re: How do you.....
I didnt remove the battery or undertray either. it's not difficult to get out the way I did mine. No point in creating more work with removiing exhaust, battery, undertray etc
iDemonix
Re: How do you.....
Post by iDemonix »
Ahh philfingers, if only you'd filmed or photoed it, would of been very useful :P
philfingers
Re: How do you.....
it's not rocket science really! from memory
Support bike on abba stand
remove rear wheel
remove seat unit, pretty sure i didn't remove the tank
remove the RHS footrest hanger with brake gubbins and the ex heat shield etc
remove the shock linkages
I think the shock comes out the bottom, over the top of the exhaust whilst lifting the swingarm up
I very definitely didn't remove the battery, undertray or subframe. My bike is bog stock, other than it's now fitted with an Ohlins rear dampers and RO fork kit
dx400r
Re: How do you.....
Post by dx400r »
philfingers wrote:I didnt remove the battery or undertray either. it's not difficult to get out the way I did mine. No point in creating more work with removiing exhaust, battery, undertray etc
True it creates a little more work. The only reason the battery comes out is you dont want it falling out when you point the subframe upwards. It also allows that mudflap thing to get out your way so you can get in there easily.
Still, everyones way works. 8-)
philfingers
Re: How do you.....
DX4, I didn't realise you were so local to me!
Jashdown
Re: How do you.....
Post by Jashdown »
Well considering my bike is already in pieces, it shouldn't be much of a problem to change the shock! Time to piss fart around with the bloody 600RR shock to get it to fit.
dx400r
Re: How do you.....
Post by dx400r »
philfingers wrote:DX4, I didn't realise you were so local to me!
:sshh: ;) 8-)
