Page 2 of 2
Re: help needed fitting a m-max box
Posted: Sun Nov 20, 2011 3:22 am
by jcxbox12345
i still havent worked it out i dont mind to much as its winter weather any way but would like to get sorted asap
Posted: Mon Nov 21, 2011 8:48 pm
by Variablevalves suck
There is no black/red wire on the 73a so you'll have to work it out on yourself. I wonder if its off a 76a!
You can derestrict the 73a by simply fitting a 1.5K ohm resistor to the cdi end of the green/yell wire that goes to the gear sensor. this is connected to the frame so the cdi only reads 1.5k ohm, the other end of the green/yell wire that goes to the gear sensor is left loose, sorted!!
