HRC NC23 Bike
- Yakama
Re: HRC NC23 Bike
Got this in a mag I bought recently, this bike i'm pretty sure raced at the suzuka 4 hour race in 1988
- Yakama
Re: HRC NC23 Bike
To add to this topic, turns out this HRC manual isnt the only one for the NC23:
I have now found the Set up manual that goes with it:
It goes into detail such as carb set up, what electrical parts to remove, the differences between the STandard and HRC pistons, rods and cams etc etc and also has lots of close up shots of a full F3 spec bike.
Very nice indeed if you are an F3 geek like me
- royster81
Re: HRC NC23 Bike
I approve of this topic very very much !!!!
- Yakama
Re: HRC NC23 Bike
Thank you
Been trying to find more out about the F3 CBR400's for years now but only recently have I managed to find stuff like these manuals and track down some actual bikes still about
Portlandpike
- Bike owned: rs125 , nc23
Re: HRC NC23 Bike
Gd find Yakama, the only pics I've seen with the hrc sub radiator fitted to nc23
Jake
Jake
- Yakama
Re: HRC NC23 Bike
That bike above won the Suzuka 4 hour in 88. It is a weird mix of nc23 aero and triarm hence the aero swingarm but triarm frame
- Yakama
Re: HRC NC23 Bike
Also I would note to run the hrc lower rad you need the hrc exhaust as it runs closer to the engine, other exhausts will hit the rad. The hrc lower rad is very similar to the nc30 lower rad
Portlandpike
Re: HRC NC23 Bike
I love the colours it's got I might have to copy them lol, but I got my wheels sprayed black and that's very good to know about the hrc exhaust being shorter to allow for the extra rad I did wonder how they fitted it?
Also do they run the main radiator as a standard one, when the hrc sub radiator is fitted or a hrc top rad aswell as lower?
Thanks again Yakama
Thanks again Yakama
Portlandpike
Re: HRC NC23 Bike
Hi Yakama
I've now been hunting for the swingarm in the picture and I Carnt seem to find it, I believe it's not a aero swingarm due to the weld running down the middle and the chain tensioned arnt the same, the aero once go inside the swingarm ends and the ones in the pic look like nc23 chain adjuster than go around the swingarm ends?
Also why do you believe they done it, could it be to save on weight maybe?
Mayny thanks Jake
Mayny thanks Jake
