Bike wont rev over 5k, help!!
Tom1
Bike owned: 1990 VFR400 NC30
Re: Bike wont rev over 5k, help!!
Post by Tom1 »
Thanks for the quick reply.
And that will de-restrict the bike?
Well it'll let it rev over 5500rpm.
JDM bikes were limited to 180km/h.
Once it's running again, if you find it stops dead at around 180km/h then it's still restricted.
A common way of desrestricting them is to open the speedo (it's only screwed together, not sealed so comes apart easy)
You'll see a metal disc that contacts sensors when the needle hits 180km/h. If you manually turn the needle to around 180km/h you'll soon know the disc as it moves inbetween two sensors. It's probably around 3cm long.
This metal disc is only tacked on with two rivits and a small flat bladed screwdriver will pop it off, and no more restriction. You must still leave the speedo-board connected so the bike thinks the speedo sensor is still inplace but with no disc to trigger it then device will never kick in.
You can also buy plug-in boxes and other gear but this is the easiest / chepeast way to do it and it's undetectable unless you take the speedo apart again.
Tom1
Post by Tom1 »
Right so even though i have a koso speedo, i still need to connect the the speedo board to the bike, but it wont be restricted to 180km/h..
Sorry ive never understood it.
Thanks again
Tom1 wrote:Right so even though i have a koso speedo, i still need to connect the the speedo board to the bike, but it wont be restricted to 180km/h..
Thanks again
Thats your problem then!
You don't have the speedo board connected.
If your not using the original speedo you can use a resistor in place of the large (in comparission) speedo board.
Find the plug thats by your clocks that originally plugged into the speedo clocks.
Get a 2.2k ohm resistor.. about 6p from maplins.
Here's a high-res pic on how to do it. but all you do is connect the resistor to the two outer wires in that plug.. brown/black and orange blue I believe.. You can cut the plug off and solder it straight to the wires if you want, just make sure to use some heat-shrink tube to fully insulate it.
http://www.400greybike.com/files/NC30%2 ... 20how2.jpg
Tom1
Post by Tom1 »
Thats fantastic! Thanks a lot, ill let you lads know how i get on!
Bike owned: VFR400
Post by magg »
There is a resistor bypass mod that can substitute for the speedo sensor if you prefer.
magg wrote:There is a resistor bypass mod that can substitute for the speedo sensor if you prefer.
Read my original post, it's already covered.
Bike owned: VFR400
Post by magg »
My apologies I missed the second page of the post.
Tom1
Post by Tom1 »
So with this high res pic, all i need to do it the Speedo plug end. I dont need to do the resistor mod at cdi end do i?
Bike owned: VFR400
Post by magg »
Yes, you put the resistor at one end or the other but not both.
