Page 2 of 4
Re: URGENT again! bike wont start now...??
Posted: Fri Sep 16, 2011 1:37 am
by Andy_Edw
xivlia wrote:another thing. cleaned my spark plugs by submergeing them in non-leaded petrol for 4 days...could that have broken the plugs?
I'm sorry but that made laugh a fair bit!
Posted: Fri Sep 16, 2011 1:42 am
by xivlia
:D im actually laughing about it now too. i thought i fucked the whole bike up. but its only plugs!
Posted: Fri Sep 16, 2011 8:59 am
by arsey30
Dry them out by heating up on the gas ring or hot air gun and check for a spark, wetted plugs can often be made to work.
Worth a try.
Posted: Fri Sep 16, 2011 10:51 am
by xivlia
ok. can anyone tell me what that thin hose in the picture is for?
Posted: Fri Sep 16, 2011 10:55 am
is it attached at the bottom? I think it is the airbox breather - you don't need it
Posted: Fri Sep 16, 2011 11:27 am
by xivlia
yeah it goes down to the bottom. but ive alreaddy attached my airbox breather.. and i checked my plugs by removing them and connecting the HT lead onto it and while holding it in my hand i pressed ignition and they are not sparking, so it must be the plugs. ive also check my carbs there is fuel inside them as i tested it by unscrewing the drain valve and fuel comes out.
Posted: Fri Sep 16, 2011 12:29 pm
you have to earth the plugs to get them to spark, touch the socket flats on an engine bolt...then try it - try not to shock yourself
Posted: Fri Sep 16, 2011 12:31 pm
by magg
Might I suggest that the hose without a home is part of the tank breather system. My hard to follow hose and wiring layout diagram indicates that the tank vent hose runs to a three way joiner and from there a separate hose runs down each side of the engine, why I have no idea. Cannot guarantee my diagram applies to all NC30 variants but worth a look.
No spark may also mean NO SPARK, not dud plugs. Try removing one spark plug and inserting a piece of wire into a plug cap and spacing the wire 5 mm from the frame and hitting the start button. If there is spark it should be visible as it jumps to frame. KEEP FINGERS AWAY!!
Posted: Fri Sep 16, 2011 1:48 pm
by xivlia
okay, ive almost got it to start now. engine fires and dies. but its getting closer and closer...but my battery has almost died now..i dont have a charger. would i be able to charge it with my dads car or is car batteries enough to blow bike battries?
Posted: Fri Sep 16, 2011 1:56 pm
by Andy_Edw
Try bump it?
