honda vfr 400 nc30 not starting.
Re: honda vfr 400 nc30 not starting.
no. you can use jump leads if you want to - but let it cool between 15s attempts
charging system failure is also common...
quinn12
- Bike owned: yamaha tzr250, honda vfr400r
Ok thanks,
Got a multi meter here somewhere, what should the voltage be when charging?
approx 14v - any higher than 15 and you have a fucked regulator and any lower you have a fucker regulator and/or knackered stator!
check the wiring and connectors too - they can get brittle and char with age!
quinn12
hi guys
just to let you know, It was the battery, the moment I put the battery in that I got from honda... she started, now just to take the carbs of and set the jets right, she only revs to 9000rpm when warm.
You guys rocks.. thanks for all the help
