something came loos
Re: somthing came loos
I'm usually the first to take the piss out of poor English. It boils my piss.
This dude, innit, has got some problems and he needs our help. If only we could understand what the problem was without resorting to translation.
As with the others - Mr OP - get the covers off and have a look. Are your mechanical skills good?
MK88
Re: something came loos
Post by MK88 »
Morning To all
Sorry for the bad English I can not type in full when I type from my cell phone that is why I short type
But let’s try it again. I set the Valve Clearance with the help of vipper’s blog Took the bike out for a ride the performance was great far better then before as I came to a stand still it sounded like something came loos in cylinder 1 & now I am to scared to start the bike again don’t want my motor to jam up. I now have a shutter noise in Cylinder 1 and 3 It sounds like a tapping sound. Mechanically I am not bad but I don’t now much about bikes I took my bike to several garages and every time they say it is right it still doesn’t have any power. So I decided I will look at it myself so after I decided to check for valve clearance as that was my last option. I did change the valve clearance and for the first time since I owe this bike it idled on its own. There was definitely more performance and a big difference in the bike except for the tapping noise. I don’t now what to be looking for as I said I am not that good with bikes but I am learning as I go Thank you all for the replies
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Stop posting the same question in new topics over and over again. if i have to remove another identical one in random sections again next thing to go will be your account. please do not do it.
if you cant type on your cellphone - then use a bloody computer. simple as.
reason no one is that forthcoming with an answer in my mind is quite simple, its because no one can understand a work you are saying. you are not describing the issue very well.
more detail and slow down, from start to finish, and use a computer for gods sake.
