Re: Does anyone recognize this vfr body kit?
Posted: Mon Aug 18, 2008 8:03 pm
I bought one ages ago seat unit ok but needs subframe modding brackets to tilt the subframe and bits need repositioning and welding a bracket to support the rear seat. But the front end I have finally given up and ordered the alternative Thailand manufacturers front. The fairing needed moving forward then it rubbed on the front wheel. I have to use the original lights mounted on their housing and couldn't get it all in the area like clocks etc. So if all you want is the seat unit yes you'll have some work to do but not as much as the you would the front. But if your up for a challange you can buy mine.
