Nc35 carb jetting help please
Re: Nc35 carb jetting help please
The extra washer raises the needle (richer) an extra 0.5mm through its whole movement.Drunkn Munky wrote:If anything the springs will have richened up your midrange meaning you were lean beforehand.trude wrote:I have an ethos half system on my nc35 which I tried with 110's and an extra washer. The top end was good but too rich in the midrange.
I then put in some hrc springs from Rick Oliver and took out the extra washer and it felt so much better.
So in summary, 110's and rick Oliver springs is a good combo. But you probably got that message already
The hrc slide springs don't make a linear change to needle fuelling like an extra washer does. The springs richen up the midrange without affecting other rev areas as much as an extra washer would. A better option in my opinion, and quite cheap from Rick Oliver.
See my (crap) diagram below for a rough comparison behind the theory (it's not to scale). Yes I was bored at work one day...
- CRM
nice graph. cammo tell me what you make of this. are you sitting comfy ?
112/117, 1.5/8 12.5mm = easy to start, idle nice, pulls stronger when warm low down, flat between 5-7k, pulls strong to the red in all gears after 8k
112/115, 1.5/8 12.5mm = as above perhaps felt a bit nicer up top, mid range the same.
112/112 1.5/8 12.5mm + extra washer = as above but pulls harder after flat spot, flat spot feels possibly a bit easier to live with.
112/112 1.5/8 12.5mm + extra washer + 8mm shorter springs = as above, stronger again up top to the red, mid feels same really.
i really do wonder if i have one air circuit in one carb with issues. any idea which ? they all seem to blow through fine.
- CRM
However - i have found something. small but might make a difference.
one of the airscrews had no metal washer or rubber sealing washer.
now i wonder if that was upsetting the midrange in any way.
fixed it now, grease on the orings and set all to 1 5/8 so lets see what happens next run out
