Page 2 of 3
Re: SP carbs again, engine blown too!
Posted: Wed Apr 27, 2011 11:39 pm
by Armi400
Hope it all works out for ya man.........there are helpful people on here, as i've come to realise.
Posted: Thu Apr 28, 2011 9:51 pm
by 4hundread
S
Posted: Thu Apr 28, 2011 10:11 pm
by stripes1976
4hundread wrote:Started to drop the engine out earlier, nearly there, just the mounting bolts left. Haven't opened it up to
see what happened, will just throw it at the back of the shed.
I am going to put the SP engine in at the moment, will use the standard carbs and swap the pick ups
over. If that fails I will try to pick up an SP brain, fit the carbs and loom.
If both these plans fail I will buy another 76a. I think it would be cheaper to buy another than to
rebuild the engine. Maybe.
si
Take the left side cover off both engines. If the rotors are the same then no need to swap cdi's or anything. The pick ups are the same on all. Just stick the standard inlet rubbers on the sp and use your std carbs on it. Because the intakes are smaller you will have better low end response which the standard sp lacks at low speed.
You have my number don't hesitate to call.
Posted: Thu Apr 28, 2011 11:36 pm
by 4hundread
T
Posted: Sat Apr 30, 2011 10:36 pm
by 4hundread
S
Posted: Tue May 03, 2011 10:27 pm
by 4hundread
S
Posted: Wed May 04, 2011 5:38 pm
by Armi400
Blimet............good luck man.....hope you manage to keep your bike on the road.
God knows, you've tried :shock:
Posted: Wed May 04, 2011 10:28 pm
by 4hundread
E
Posted: Wed May 04, 2011 11:29 pm
by stripes1976
If you do decide to build one out of two make sure you ring me first as there are some important do's and don't with these
Posted: Thu May 05, 2011 7:43 am
by dobbslc
Hi guys I've just been reading this thread sorry about the bad luck with those engines, I've had a similar saga with mine over the last 3 months I rebuilt the top end with new valve guide seals head gasket reground the vales etc put back together got it running well after much fiddling about but it smokes when riding it now!!!! :x
Mr Stripes can you tell me what the important do's & dont's are you mentioned? maybe I missed somthing. I don't want to give up yet.
Thanks.
Rob
