Page 2 of 2
Re: NC30 Front Fairing - Misaligned!
Posted: Tue Mar 29, 2011 3:21 pm
by Martin
iArGod wrote:Martin wrote:You should have rubber boots around the headlamps which would get rid of that gap, see the pic below.
Is this a standard thing?
Or is that made up by someone?
It's standard chum.
Posted: Tue Mar 29, 2011 10:00 pm
by iArGod
I found a website that sold that headlight with the rubber seal,
I contacted them about the seals separately; but apparently honda has discontinued them and they no longer have stock
Anyone know of somewhere that has these in stock?
Posted: Tue Mar 29, 2011 10:02 pm
by CRM
send geoff33 a PM on here, am sure he can help, or if you search, you can find info about using an old inner tube to make a replacement to very good effect.
Posted: Tue Mar 29, 2011 11:34 pm
by Cammo
Hadies wrote:My right hand rubber headlight surround has come off and there is a gap, but it shouldn't be that big.
+1, that is a huge gap.
The rubbers won't fit properly with a gap that big.....
Posted: Wed Mar 30, 2011 1:04 am
by Dynamohum
fairing stay clock/headlamp mount bent at a guess was the old nose cone damaged in an accident hence the tyga replacement
Posted: Wed Mar 30, 2011 3:09 pm
by matt_vfr
You say it fits at the top... is this with all other fairings fitted (lowers)? There should be a bit of a gap (5mm ish) which is filled with a combination of foam stuck to the rear of the top fairing, and the rubbers on the lights that others have mentioned. If you have tried this without any lowers then try jiggling the fairing around to make the gap consistent around the full circumference of the light and then measure it. If that doesn't give you any joy then
on a bent headlight bracket!
Matt
Posted: Wed Mar 30, 2011 3:19 pm
by krisztian_andre
It's probably the fairing stay clock/headlamp mount, beware of the chinese stays on ebay they are of horrible quality and result in misaligment as well, though not so bad as on your photo.
