VFR NC30 idling/ revving issues
Re: VFR NC30 idling/ revving issues
The ppoint I was getting at is that th bikle does run, but has all the classic signs of an air leak.
Where you at? If you are local I can loan you a CDI to test.
VFR-Element
- Bike owned: 00'R6-02'R6-07'R6-04'CBR600RR
Yes i agree, the idling does sound like a air flow issue. Unfortunately I'm @ Centurion, South Africa. I am going to a shop today and testing with working CDI.
right..I've been to Centurion - near jo'burg?
So, you are at altitude - and the 115/118 might be rich for you..that is a by the by..but might be worth thinking about.
If you get it running and spray some carb cleaner/flammable aerosol at the rubbers, does it pick up revs? Simple as that, I reckon simple fixes are best!
VFR-Element
Yeah Centurion's in Pretoria the Capital!!! about 37 miles from Jo-Burg. Most beautiful places to ride around PTA. The jetting is set for UK but ive been running the bike here before it broke down and was a very strong/fast runner.
I havent yet tested the rubbers like that but will do that a bit later today. Gonna go look at my new potential superbike first and test the CDI while im there.
cool... I stayed in Pretoria when my mate married a Saffa lady. It was a random place indeed..but a good experience.
6000ft up isn't it? I'd lean it off a touch - more power, better miler per gallon... win!
VFR-Element
Ok so, ive manged to get the idling sorted by replacing the carb rubbers. I decided to take the carbs off and check the jetting and so on for the last time. The bike is idling perfect and the choke plus idling screw now works. However, the revs still get limited to 8000RPM. I am really starting to suspect the CDI. Someone suggested i derestrict the speedo manually with a 2.2k resistor but i dont think its the speedo as the revs get limited and not the speed. Would the speedo restriction make a difference?
Can you unplug the speedo (behind the clocks) and see what happens?
On a std CDI this will give you a rev restriction at 5.5k revs - it will only fire 2 cylinders.
This will find out whether the CDI is restricted at all.
Have you checked your plugs recently? All this starting and rough running will be bad for them so they might need a clean off or they'll die!
VFR-Element
I unplugged the speedo and no difference, bike does exactly the same. I checked the spark plugs again yesterday and also made sure they were not loose. Spark plugs are brand new and all of them looked fine.
VFR-Element
To Whom ever sent me this mail. The forum did not supply any return details and therefore I am unable to reply to your request via mail. I will be able to help you with carb rubbers and it can be couriered to you overnight. If you are still interested, please send me a reply and we can arrange things from there.
Hello VFR-Element,
The following is an e-mail sent to you by SilverSurfer via your account on
"400greybike.com". If this message is spam, contains abusive or other
comments you find offensive please contact the webmaster of the board at
the following address:
Forum_no_reply@400greybike.com
Include this full e-mail (particularly the headers). Please note that the
reply address to this e-mail has been set to that of SilverSurfer.
Message sent to you follows
by VFR-Element » Mon Mar 28, 2011 9:00 am
i hope u can assist i`m unable to find carb inlet rubbers for my NC30
where if possible did u get new one`s ? btw. i`m from Rustenburg, and there
aren`t that many nc30`s around
Hello VFR-Element,
owen_captain
- Bike owned: xs1100, xt250, VFR400 NC30
Hey boetVFR-Element wrote:To Whom ever sent me this mail. The forum did not supply any return details and therefore I am unable to reply to your request via mail. I will be able to help you with carb rubbers and it can be couriered to you overnight. If you are still interested, please send me a reply and we can arrange things from there.
Hello VFR-Element,
K, it wasent me that sent the email, but just wanted to know btw how much are your Carb rubbers with postage to Durbs?
Shot
