wont go over 40 mph
anp
Re: wont go over 40 mph
No the dyno printout was 15 years ago it made 6 hp more at mid range & 4 hp more at the top end the exhaust is a standard can with the reflected system removed and an absobtion tube fitted
I rekon a new set of carbs is the answer the old ones must still be blocked shame the bike has only done 7000 miles
Thanks for the suggestions
- Matchlessman
Hi,
Have you drained the tank and put fresh fuel in?
anp
Yes I cleaned out the tank but while I am working on the bike at the moment I use a dummy tank that holds a litre or so of fuel
I have identified this afternoon by a process of elimination that cylinder no 1 in is at fault has a spark & compression but no fuel so it looks as if a new set of carbs are required
anyone have a set for sale or know someone who has ?
Paul
Paul
