NC30 cylinder 1 vacuum issue
Re: NC30 cylinder 1 vacuum issue
yeah i cut short my garage mission today, got rear sets on and half bleed the rear brake, got as far as getting juice out and then thought ill finish off tomorrow my toes felt as if they were going to drop of.gonzothegreat wrote:ok, well it's way too cold and too dark now and I'm hungry... to go back to the garage.
I'll give it another go at balancing it either tomorrow after work or next week-end,
thanks for the advice, will keep you all posted.
- skinnydog0_0
- Bike owned: Penny Farthing
It may be the carb rubber on C1 is letting in air. where they all in good condition when you put them back on?
- thunderace
- Bike owned: R6, YZF600R
gonzothegreat wrote:all the 4 vacuum ports are connected to the carbtune, the fuel tap has vacuum applied to it with a small hand vacuum pump.
The idle is rock solid at 1500 RPMs, just this cylinder #1 is acting odd.
It wasn't the case with the NC30 carbs, I have a video of it if you want to see.
I meant the vacuum take off for the fuel tap, not the balance gauge fitting
brand new rubbers :)
skinnydog0_0 wrote:It may be the carb rubber on C1 is letting in air. where they all in good condition when you put them back on?
Gave up on trying to balance the NC35 carbs like I had done the NC30 ones. I used a 2mm drill-bit and used that to set the butterflies
Got everything back on, bike idles fine, revs fine. Took it for a ride and it's fine, no bog down, no flat spot.
It's a little bit less nippy than before with the NC30 carbs below 4-5000(ish) RPMs but more lively in the upper RPMs.
Now, here's something interesting, the exhaust note has changed. It does sound differently now
That will be due to the dead rear coil
Took the bike to work and back today, sounded like a twin.... I checked the spark on all four cylinders and the rear ones are so weak you can hardly see them.
gonzothegreat wrote: Now, here's something interesting, the exhaust note has changed. It does sound differently now.
