Page 2 of 27
Re: Porndoguk/RickyB_DJ - VFR400 R3K NC30
Posted: Sun Jan 09, 2011 2:06 pm
by Drunkn Munky
Great write up ricky and :plus: for going back to the SEED scheme
Posted: Sun Jan 09, 2011 2:39 pm
by ibby4585
Ricky I will sort some pics out for you tomorrow. I'm off for four after tonight
Kris
Posted: Sun Jan 09, 2011 11:04 pm
by rob b
Nice post Ricky.
I like all the posts like these allways looking for up dates every day.
& I can't thank you guys for the help you give.
Cheers.
Rob.
Posted: Mon Jan 10, 2011 10:07 am
by porndoguk
cheers guys, more pics and write ups to come i have missed loads and will probally edit or just add to the topic, this weekend ive spent small time out in the garage but had a good crack and rebuilding the swing arm and bits, also filled with expanding foam etc,
Posted: Mon Jan 10, 2011 1:53 pm
by ibby4585
Ricky.
Ive emailed you some of my Seed pics, hope they help.
Kris
Posted: Mon Jan 10, 2011 3:21 pm
by porndoguk
ibby4585 wrote:Ricky.
Kris
Thanks man.
Posted: Mon Jan 10, 2011 6:02 pm
by Benneyboy@1984
[quote="porndoguk"]cheers guys, more pics and write ups to come i have missed loads and will probally edit or just add to the topic, this weekend ive spent small time out in the garage but had a good crack and rebuilding the swing arm and bits, also filled with expanding foam etc,[/quote]
expanding foam ? please tell me more lol :o
Posted: Mon Jan 10, 2011 7:06 pm
by Speedy
Another :plus: for going back to the SEED scheme! You only have to look at Kris's fine example to see it makes sense! 8-) By the way Kris, who resprayed that and the OKI one?
@ Benneyboy@1984, the expanding foam is for plugging the 2 front holes on the swingarm (where the rear shock goes through), so that it stops sand and little stones getting in and getting to the rear end of it and jamming the chain adjuster! Any hardware shop will have that foam in a can! :smile:
Posted: Tue Jan 11, 2011 9:36 am
by porndoguk
as speedy says its to stop crap from getting into the hollow swingarm,
it mainly stops the hub getting seized/dirty internally, keeps out water in bad weather, and stones/pebbles which rattle around inside, i took loads out when i removed the wingarm there was a right pile of dirt.
Rick
Posted: Sun Jan 16, 2011 11:32 pm
by porndoguk
More Pics of last fews weeks work,
DIY - K&N
Piper X Breather
Valve Clearance Check - Rear
Front Brake Resovoir, W&D and then Lacquered
Rear Caliper Overhaul
Seized Pistons Before
Polished Pistons After (Condensation!)
New Seals
Job Jobbed
