nc23 limit
petrolhead19
Bike owned: 2 x nc23's 1 x nc29
Re: nc23 limit
Post by petrolhead19 »
im using the sprocket cover and speedo drive from the new engine, i might try putting the old one back on see if that helps.
The only thing i have messed about with are the electrics
Matchlessman
Re: nc23 limit
Post by Matchlessman »
As a quickie, try disconnecting the speedo cable. that should tell you if its hitting a top speed limiter.
Did you do a compression test on the engine before fitting it? presumably as well you made sure it didnt have 33bhp restrictor washers in.
petrolhead19
Re: nc23 limit
well i will try that this weekend and yes i did a compression test and everything was fine,
i had the carbs off but didnt notice any washers but im taking the carbs off this weekend so will double check
Wozza
Re: nc23 limit
Post by Wozza »
Are you using the same carbs as before or did the engine come with a set?
petrolhead19
Re: nc23 limit
the engine did come with a set but i am using my carbs off the old engine as i know there perfect and nothing wrong with them, plus couldnt be bothered stripping and cleaning the carbs that came with the engine lol
