Whats your favourite NC29 Rear Shock?
vr46
Bike owned: All sorts
Re: Whats your favourite NC29 Rear Shock?
Post by vr46 »
Wozza
Post by Wozza »
For those who have jacked up the rear, has anyone measured the front wheel trail? I'm interested to know how small you can safely go.
Troyus
Bike owned: x2 CBR400 NC29s
Post by Troyus »
Is there anyway of replacing the link pipe between the shock & the reservoir (like on the CBR600 F4i etc) so that the reswervoir can be located where I want it? Have been looking to replace the standard shock on my 400 cos its condition is deteriating quickly and this seems to be a cheap replacement (upgrade? :?: )
Also while on the subject - when it comes to changing the spring on the shock -how do I work out what weight spring I should be relacing it with- Have been looking at K-teck spings - they have six different options but the only obvious difference between them is the end two numbers of there product code e.g
HKZ31-380-5X-50
HKZ31-380-5X-52
ETC ETC ETC -54
ETC ETC ETC -56
ETC ETC ETC -57
ETC ETC ETC ETC ETC ETC... YOU get the idea
Are the final two numbers a weight rating or dependant on how many pies you've eaten that morning... heres the http for you to have a look for yourself
http://www.k-tech.uk.com/store.php?cate ... &Submit=Go
garyboy_palaboy
Post by garyboy_palaboy »
i got is a FOX TC-R Rear Shocks
Fully adjustable, preload and rebound. little bit tricky when installing, you have to remove the fuel cock knob.
cajun
Bike owned: MC22, NC29,NC35, 2 FZR400's
Post by cajun »
Peneske Double Clicker made in the US. Long remote res that can be mounted anywhere and a snap to change springs with 36 clicks of adjustment.
PARUS------ How much to you weigh in lbs? I Think your spring is too light. I've went through an extensive set-up on mine.
PARUS
Post by PARUS »
Sorry, I don't remember the shock weight, but it was lighter little bit. As for the spring I have HyperPro 6x850 progressive. I'll try to find spring rate to compare with stock.
cajun
Post by cajun »
PARUS---I misread your post. I thought you stated you have a 600lbs spring. But yeah a 850-900 would be about right guessing by your weight in the pics.
rickee
Post by rickee »
For those that have CBR600 shocks installed, where did you mount the reservoir?
Wozza
Post by Wozza »
rickee wrote:For those that have CBR600 shocks installed, where did you mount the reservoir?
People often mount it to the exhaust can hanger but I found this got in the way of my foot, so I attached mine to the subframe LHS under the seat.
rickee
Post by rickee »
ah,, I've ended up with mine on the subframe RHS, tucked high up behind the pillion peg. You can see a loop of tube on that side of the bike but is not in the way.
