Rear Caliper Pistons?
porndoguk
Re: Rear Caliper Pistons?
Post by porndoguk »
i guess that would work they are very similar to these, but dont have the line near the edge there perfectly flush.
http://image.made-in-china.com/2f0j00MB ... sap02-.jpg
http://www.davidsilverspares.co.uk/grap ... _large.jpg
http://akhara.com/nc30/nc30parts/files/031.gif
partnumber 17 / 45107-MN5-006
thunderace, if i were to send one of the removed pistons do you think you could machine one in stainless?
what sort of price would you want for them?
cheers Rick
You can get 35mm x 300mm stainless steel bar for around 25.00, but the cost of setting up / turning them down and hollowing them out soon adds up if your paying someone to do it.
If you know somone with some SS bar knocking around and time to spend machining them down then it isn't so bad.
23.00 each from wemoto with both the seals too.. the seals are about 5.00 so your paying about 18.00 a piston. (i would always use new seals with new pistons btw)
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
My best mate works for the largest SS stockholder in the UK ;)
He should be back from honeymoon by now. I'll speak to him this week :mrgreen:
porndoguk
Post by porndoguk »
Neosophist wrote:You can get 35mm x 300mm stainless steel bar for around 25.00, but the cost of setting up / turning them down and hollowing them out soon adds up if your paying someone to do it.
i bought new seals last week from DSS! FFS arrrrgh im gettin peeved with spending and wasting money all the time!
Your an eager beaver!!
:mrgreen:
Put down the credit-card and shop around first... :)
it looks as though luck might be on your side anyawy with thunderace getting you some pistons!!
Whats up with the old ones outta curiosity?
porndoguk
Post by porndoguk »
Neosophist wrote:Your an eager beaver!!
:mrgreen:
had to butcher then to get them out seized in,
couldnt get them out with brakefluid and pressure
nore 180PSI of air,
so was blowtorch and pliers!
the other i had to drill a dent into the piston and use a centre punch to lever it out against a 12mm spanner!
i think ill just gently clean the pistons on my working rear caliper when it comes to swapping them over, a good heavy degrese with solvents and suchlike, and then use polishing compound with the dremmel i dont want to damage the surface to much as i will lose the diameter. I also have a banjo switch, so when i do eventually sort my rear sets its a case of just unbolting without the need of sorting brake fluid yet again!
and gonna also sort all my resovoir hoses as they are leaking AGAIN with to layers of pipe!
