NC23 RUNNING RICH OR LEAN?
Wozza
Re: NC23 RUNNING RICH OR LEAN?
Post by Wozza »
I've got an idea..........
c7ll
Post by c7ll »
Ok I'm going to balance the carbs again and then take it out...
Wozza
Post by Wozza »
Oh I completely missed in your first post that you said carbs were balanced :oops:
But how long ago was that? As I had the same problem on my bike where one of the downpipes didn't heat up properly on tickover and balancing cured it, even though they'd been balanced about a year before (not by me though so possibly not done well enough).
c7ll
Post by c7ll »
I balanced them about 200 miles ago and they certainly needed it, before that it would hardly run at all, but no harm in just eliminating this from the equation so will check it again.
Still cannot understand why leaning it in (turning the mixture screw clockwise) is causing that cyclinder to fire when screwing it out (rich) is stopping it from firing on idle. could it be providing so much fuel that it's flooding the spark?
jac_is_smiling
Bike owned: Cagiva Planet, NC23 x2, FZ 600
Post by jac_is_smiling »
Could it be...the idle mix screw has the tip of it broken off? The little brass screw has an almost needle like tip on it, if that has broken off then it may be running crazy rich on 2.5 turns out, then once you screw it in, it leans it back to something approaching normal?
Failing that have you still got the little rubber o-rings on the idle mix screws?
Ive had trouble before when a couple of them were missing, caused some really odd running.
Wozza
Post by Wozza »
As jac says, also you could replace the pilot screw o-rings as they're old, that's something I did recently actually. My local DIY shop had a box of assorted o-rings, they need to be 3mm OD 1mm ID 1mm thick iirc.
c7ll
Post by c7ll »
Checked the needles and they're fine. Where do the o-rings sit?
Wozza
Post by Wozza »
On each pilot screw should be a spring, a washer and then the o-ring - often the o-ring doesn't come out with the screw but stays inside the carb so you'll need to poke it out or tap the carbs.
c7ll
Post by c7ll »
Problem solved - transpired it had no o-ring at all!, now running fine at 2.5 turns - thanks guys
