Page 2 of 3
Re: NC24 Carbs - HELP!
Posted: Sun Sep 12, 2010 4:48 pm
by GeoffMM
Took a look and the cause was the pin that holds the float valve was sticking.
Freed this up and now i have a stutter issue so will clean the plugs etc.
Posted: Sun Sep 12, 2010 8:15 pm
by thunderace
Took plugs out today, looks like the rear ones are fairly new but the front ones have obviously not been changed in quite a while
Now trying to source new ones, so fasr the results ain't cheap
Posted: Mon Sep 13, 2010 10:32 am
thunderace wrote:Took plugs out today, looks like the rear ones are fairly new but the front ones have obviously not been changed in quite a while
Where are you sourcing them from?
The factory ones are C8EH9 which are about £6 each...
Most people use resistor plugs as they are cheaper.. slightly weaker spark but plenty of people run them no problems.
You can get a pack of 10 from the USA for £20.00
Plugs
davidsilverspares also sell both the standad C8EH9's and the CR8EH9's... just be glad you dont' have an NC30.. the plugs in that are 2x that price.
Posted: Mon Sep 13, 2010 11:10 am
by thunderace
With the current conversion rates, they're a bit more than £20 bud
I've looked on the Bay and a few other online places. Cheapest so far is Silvers at just under £7 each for NGK. That's still not cheap though, I'm used to paying around £3 each for NGK plugs but they are the resistor type.
I'm not going to mess about fitting resistor plugs because the HT leads are fine, they look fairly new tbh, so I don't see the point in replacing them to non-restance leads.
Posted: Mon Sep 13, 2010 12:22 pm
thunderace wrote:With the current conversion rates, they're a bit more than £20 bud
Erm
$30.99 usd is £20.32 at todays exchange rate.
Thats £2 each plug (there a pack of 10)... how did I loose you?
Fitting resistor plugs is no more different than fitting non resistor plugs.. they look identical apart from their internal construction.
Posted: Mon Sep 13, 2010 2:34 pm
by thunderace
My bad, I read the eBay ad wrong. Still £30 with shipping though (and I no longer have an eBay account - they won't let me have one either since I sued them
). I'll probably just go with Silvers.
Posted: Mon Sep 13, 2010 5:00 pm
Indeed but for 10 plugs :D
You'll pay that from DSS for 4!
Erm.. the resistor plugs (CR8EH9's) are identical to the C8's apart from internal construction.
Most people just fit these as there cheaper.. if you look at DSS's 'service kit' they sell for the NC24 they include the CR8's with that.
Using resistor plugs and resistor leads might lead to a slightly weaker spark, but theres plenty of people on here with CR8's in their bikes with no problems, I've had dyno's of 24's running both plugs with standard leads and no difference was noted.
If you can get them cheaper they are a viable option..
Posted: Mon Sep 13, 2010 5:12 pm
by thunderace
So I can fit them without changing the leads then. Cool, cheers
Posted: Mon Sep 13, 2010 6:30 pm
Yep :)
Posted: Wed Sep 15, 2010 4:34 pm
by thunderace
Well, I've replaced the O-rings on the connecting pipes today and re-assembled the bike bar the air filter. It starts and runs, firing on all four, but only with the choke on. As soon as I blip the throttle, it stalls. Admittedly I've not been running it for more than a minute or so at a time so it will still be cold. I hope it may just be this and the lack of air filter thats causing it.
Cleaned the plugs and put the newer two in the fornt bank but they all seem OK for now so that's one less expense for the minute.
Also sorted out the electrical nightmare and got the indicators working properly. WTF do people not just use crimp terminals? Or at least a bit of terminal strip instead of twisting, taping and hoping for the best?
I will get around to doing a full on thread of my progress soon, I promise
