Why the hell my NC30 won`t start again
Re: Why the hell my NC30 won`t start again
If there is fully charged battery it should, unless its putting out too much voltage, then it might just kill your CDI along with everythign else.theoutsider wrote:The main fuse is fine,carbs are clean,but now it doesn`t even try to start,it just turns over,tried everything except changing the reg/rec because I have no funds,but it should start though with it broken?
There is fuel,there is compression(loads),and there is spark?What the hell is missing?
You might have just flooded the engine / killed the plugs, they die easy
samace
Have you checked the vacuum pipe to the petrol tap ? Mine split causing the same problem.theoutsider wrote:It`s a 30,with the right cdi,the bike ran like a dream,nothing has been replaced
theoutsider
It has the hrc tap mod
- skinnydog0_0
- Bike owned: Penny Farthing
I had a similar issue with the HRC tap mod. If you take the tap apart, make sure that the little rubber foot it through the plastic disc. My rubber diaphram had a little split and was intermittantly letting fuel through, but not enough to get it running properly. Might be worth a look. Do you have a fuel line coupling to detach the carbs from the tank and stop any fuel getting through when the petrol is turned off?
theoutsider
I don`t have a fuel line coupling but I`ll check today the tap,clean all the spark plugs,charge the battery and see how it goes.Thank you for the answers
theoutsider
chownsy
- Bike owned: KS125, ER5,VFR400 NC24
going to sound dumb, you aint accidentally knocked the engine stop on the handle bartheoutsider wrote:I don`t have a fuel line coupling but I`ll check today the tap,clean all the spark plugs,charge the battery and see how it goes.Thank you for the answers
theoutsider
No,its on run,
Neosophist wrote:If there is fully charged battery it should, unless its putting out too much voltage, then it might just kill your CDI along with everythign else.theoutsider wrote:The main fuse is fine,carbs are clean,but now it doesn`t even try to start,it just turns over,tried everything except changing the reg/rec because I have no funds,but it should start though with it broken?
theoutsider
Plugs are fine,I think it`s flooded I will leave it as it is for few days hopefully it will fire up.
