nc24 no spark
fringe80
Re: nc24 no spark
yeah tried it with both,, just the same thing happening!!!
Re: nc24 no spark
The ignition system isn't complex, there must be something wrong somewhere, have you got the wiring diagram? It's easy enough to trace
Re: nc24 no spark
I'll stick 20p on a kill switch failure...
fringe80
Re: nc24 no spark
i'll try the 1 from my other bike and let u know 2morrow,, where should i post the 20p to mate!?!?!?
fringe80
Re: nc24 no spark
ignition switch is fine,, it's must be the pickups!!
used multi-meter on everything and all good but nothing when i test the pickups!?!?
two different ones been on the bike and still nothing there!?!?
any help would be great please!?!?!?
Re: nc24 no spark
What / how are you testing them?
You need to measure resistance, 400-500 ohms on the pickup coils.
Silly question but are you earthing the plug (holding it against the engine) when your cranking the bike over?
fringe80
Re: nc24 no spark
multimeter, to be honest no sure what setting to put it on!!!but did try all setting on mine,, lost the booklet thou,,,
yeah when cranking i'm touching the plug against a nice shiny bolt on the engine!!
am i making a tit of myself and doing it all wrong!!!
Lee
Lee
Re: nc24 no spark
Sounds about right, I put it on the rocker bolts of the cylinder head.. try that (also make sure the plug is in properly)
Put the meter on Ohms (resistance) if it's got a manual scale put it on 2000
Measure between the wires on the plug
fringe80
Re: nc24 no spark
hi mate still no joy, could you explain how to check all the connectors for me please
Re: nc24 no spark
Yep.
Firstly check the coils
Put the multimeter on Volts.. 20 if it's a manual meter.
Theres two wires to each coil, put the igntion on and measure between earth and each wire on the coils and see what you have...
