3TJ Exhaust header/Downpipes replacement
RoadDogma
- Bike owned: FZR400RR (3TJ)
Re: 3TJ Exhaust header/Downpipes replacement
I have fit T-Cat pipes to a 3TJ, but they hung down a little low.
Do the R6 downpipes fit any better? I have read that R6 pipes have been mounted to T-Cats in order to gain some ground clearance.
I understand that to make R6 pipes fit, the crossover tubes need to be cut so that the primary header tubes can be spread apart. Thus, the downpipes will bolt to the FZR head. Are there any other issues to address in fitting the R6 pipes to a 3TJ? Has anyone tried the 2nd generation R6 downpipes? I'm thinking of giving them a go.
R6 pipes need to be cut and shut.
sportspromatt
hello, about two years ago, cut my down pipes of, where they connect to exup valve casing! they were knackered! sent them to Dens Exhausts, they advertise in classic bike mags, £115 later! and stainless down pipes! shaped from original mild steel 3tj pipes!, new S/s headers etc!
When i got them home, got them tig weldeed to the exup value casing! tacked first, then removed from bike, and tig welded, basically the only welding was the 4 downpies to the exup casing, ( its round in shape)
£115 and we never have to look at them again! and they clear up like new, two yrs later!!
hope this helps, no jetting, r6 pipe cutting welding etc!! its another option!! the bends follow the original bends so it fits as it should!
look in any classic bike mag, or if ur stuck, i will try and find the receipt! (tel number) they are based in London, and 100% to deal with!
heres the exhaust makers contacts:
Name, Address
Alldens Exhausts
Ardgraft works
Newtoft Business Pk
Newtoft
Market Rasen
LN8 33WA
tel; 01673 862286
Mob: 07718 113 138
Email: mike@tubeengineers.co.uk
Name, Address
Alldens Exhausts
Ardgraft works
Newtoft Business Pk
Newtoft
Market Rasen
LN8 33WA
tel; 01673 862286
Mob: 07718 113 138
Last edited by sportspromatt on Thu Jun 10, 2010 11:43 am, edited 1 time in total.
sportspromatt
here is a pic!
if you can find the number it would be very useful
sportspromatt
Name, Address
Alldens Exhausts
Ardgraft works
Newtoft Business Pk
Newtoft
Market Rasen
LN8 33WA
tel; 01673 862286
Mob: 07718 113 138
Alldens Exhausts
Ardgraft works
Newtoft Business Pk
Newtoft
Market Rasen
LN8 33WA
tel; 01673 862286
Mob: 07718 113 138
RoadDogma
Could anyone tell me what "cut and shut" means in reference to the R6 pipes?
Cut and shut = You have to cut (the small balancing pipes because the R6 cylinders are wider spaced and then the down pipes because they're too long) and shut or weld them back together.
Racers use them because they're relatively cheap and they're not botherred about looks or junking the exup. Road riders seem to think R6 ... that must be fast but the realive is they're just pipes. I'd go with the option of getting the stainless downpipes made up, you keep the exup which is good for road riding and you don't have to get the carbs set up again.
RoadDogma
Thanks Evil. I was aware of the cylinder spacing issue, but wasn't sure about the length. Application is actually for a track bike with flat slides, so this helps. I recently test fitted a set of R6 race pipes and found the collector also pointed down towards the ground, so I get the "cutting and shutting" bit now. T-Cat pipes look like less effort.
