Page 2 of 2
Re: Starting problems again
Posted: Tue Apr 27, 2010 9:45 pm
by jo
No. Nothing on dash at all. I'm gonna check the starter solenoid tomoz to eliminate that. I've had so many charging problems with my bike but the dash has never died. I will also check all earths tomorrow too,
Posted: Tue Apr 27, 2010 10:06 pm
by Old Painless
The dash is supplied via the solenoid, the battery positive is wired straight through it. You should be able to get a reading of around 12v from the battery ground terminal or frame to the correct connectors on the solenoid, you need to cross-reference the wire colours with the wiring diagram. If none of the connectors on the solenoid are giving you a voltage but the battery is giving a voltage reading, the solenoid is probably dead.
Let us know what you find.
Posted: Wed Apr 28, 2010 7:06 am
by CRM
Jo shame you dont live closer to me, i have all the parts you would need and could sort this out.
Its quite logical and i am sure following the steps you will find the problem area.
Posted: Thu Apr 29, 2010 1:04 pm
by jo
Success! It was a dead battery in the end. Got it on charge, took it to my local bike garage. We did all the voltage tests, and alt and reg/rec are both ok, but the battery was low, so i've got a new, slightly bigger one. Lets hope it's done the trick.
Thanks for the help and advice everyone. One less worry off my mind.
Posted: Fri Apr 30, 2010 2:12 pm
by NGneer
Glad you got it sorted Jo. So are you gonna stretch its legs and give it a run on Sunday to check it out, or are you being a big soft pink and girly girl and going in the car still (lol)
Give me a shout if you change your mind, if not i will see you there
Posted: Sat May 01, 2010 7:54 pm
by jo
NGneer wrote:Glad you got it sorted Jo. So are you gonna stretch its legs and give it a run on Sunday to check it out, or are you being a big soft pink and girly girl and going in the car still (lol)
I'm gonna be a girl.
I'm going in the car!
Posted: Sat May 01, 2010 9:36 pm
by NGneer
jo wrote:NGneer wrote:Glad you got it sorted Jo. So are you gonna stretch its legs and give it a run on Sunday to check it out, or are you being a big soft pink and girly girl and going in the car still (lol)
lol - Fair enuff. See you there
