Page 2 of 2
Re: HELP!!! Before i kill my dad!!!!
Posted: Mon Mar 22, 2010 7:03 pm
by Drunkn Munky
zimm wrote:large torx bit, gentle tap, unscrew, done.
This works
Posted: Mon Mar 22, 2010 9:01 pm
by fixer
When replacing plugs i push ashort piece of rubber tube over electrode end,with ashort piece of wood doweling in hose end.Locate in plug hole and turn in plug,any tight resistance would be taken up by the rubber hose so avoiding a crossed thread.Hope this is of help.
Posted: Tue Mar 23, 2010 9:25 am
by richhemmings
fixer wrote:When replacing plugs i push ashort piece of rubber tube over electrode end,with ashort piece of wood doweling in hose end.Locate in plug hole and turn in plug,any tight resistance would be taken up by the rubber hose so avoiding a crossed thread.Hope this is of help.
? I dont get?
rubber tube over the threaded end?
I've always thought screwing plug in by hand was best, then just nipping them up with a wrench / screwdriver with socket?
I use the 13mm socket with an extender bar for my NC30 as the heads are well recessed, also, if you can get tehm, or make one up, my ol' man use to use a socket with a rubber or foam insert to hold the lug strraight - makes lining it up easier.
Posted: Tue Mar 23, 2010 8:12 pm
by fixer
Posted: Wed Mar 24, 2010 7:40 pm
by Chris 91UK
PANIC OVER!!
the whole plug is now out!
stud extractor,,,,nice and slowly, came straight out in about two minutes which surprised me
so now i can talk to the old man again ( but it will be a while before he goes near the bike though!)
thanks very much for the advice greybikers,much appreciated
Posted: Wed Mar 24, 2010 8:44 pm
by w00dzy
Good stuff, bet that was a relief!
