Page 2 of 4
Re: flat spot / jetting
Posted: Mon Mar 01, 2010 9:22 pm
by lee.pb
CMSMJ1 wrote:no worries Lee..
I have the same issues on my race bike actually..
Fitted some open carbs, running 147 jets and it is too rich and messy. bogging down and making nasty noises.
As my first test is Weds and race on Sunday I am fitting std carbs, 118/120 with a normal box and filter. It won't be fast, but it will work and for now, that is good enough!
when you say open carbs i assume you mean no air filter and no airbox top or have you got the nc35 airbox top fitted? should of had a propper test ride before did oulton park on friday or should i say 1 lap in fist gear gutted
Posted: Tue Mar 02, 2010 1:30 am
by Cammo
lee.pb wrote:is it possible to get the hrc velocity stacks from the uk?
Not really, but you can restrict them in other ways. If you tap the air jets to take a allen head bolt you can then just drill this out to the required size (2mm).
Blatant show off pic of my setup:
Posted: Tue Mar 02, 2010 12:06 pm
by lee.pb
DataRacer wrote:lee.pb wrote:is it possible to get the hrc velocity stacks from the uk?
nice set up mate, i'm a little confused about the air hole location?
Posted: Tue Mar 02, 2010 1:46 pm
by lee.pb
this is what was fitted on my nc30 when it arrived.
not sure if bike has ever run correctly as only test rode up the street, and checked all gears on paddock stand.
Posted: Tue Mar 02, 2010 1:53 pm
Has it ever run since you had it? did it sit for a while and maybe needs the carbs cleaning out?
Posted: Tue Mar 02, 2010 2:05 pm
by lee.pb
CMSMJ1 wrote:Has it ever run since you had it? did it sit for a while and maybe needs the carbs cleaning out?
no never in anger, guy said carbs had been cleaned. he only run it the same as myself.
beleive the jets are a wee bit small for no filter (115), new plugs have been fitted. run ok with other carbs fitted and standard airbox. should have a second set of carbs this week going to speak to rick oliver about hrc carb kit and what jets
may be required to run it as it came as dont have a spare air box and filter.
Posted: Tue Mar 02, 2010 2:22 pm
The 115 jets are small even with a filter....
I've just fitted 140s to my carbs that look like Dataracers (although not as shiny) and need to get them working.
I also run RVF carbs on my road NC30 - that has a filter, but no lid and uses 130 jets. (std is 108)
Posted: Tue Mar 02, 2010 3:35 pm
by lee.pb
CMSMJ1 wrote:The 115 jets are small even with a filter....
my standard nc30 road bike (now) has 110 front and rear its a 89 model which has a full quill system and ran fine.
Posted: Tue Mar 02, 2010 3:38 pm
by lee.pb
where is it possible to obtain a air tray for under the carbs, seen them on ebay but none on at the moment.
carbs are off the bike at the moment so would be stupid not to fit one.
here's a pice of the PIG all ready for the track.
wheels still require powder coating.
Posted: Tue Mar 02, 2010 3:45 pm
Are you running dynojet jets?
I'd still say 110 is too lean for a full system like that quill...have you any dyno sheets?
