NC30 Midrange splutter
matt_nc30
- Thieving Pikey Twat
- Bike owned: NC30, 2000 R1
Re: NC30 Midrange splutter
Sorry, but wouldnt blocked jets affect top end? the bike revs out nicely and pulls 13.5k in top no problem.Neosophist wrote:Maybe you have some crap in the tank thats worked its way down to the carbs and is blocking one of your jets.
Inline fuel filter would help if this is the problem...
Will take carbs off over the week-end give them a clean out, sync the carbs and see about fitting a fuel filter.
Would the fuel octane level affect the running of the bike.
Thanks for all the replies.
Matt
Have you messed about with the carb slides or needles?
I.e- drilled them or inserted extra washers?
Sounds too rich so why not remove a round of washers from the needles - or check what you have already
matt_nc30
Slides have been drilled years ago, as for the needles and washers, i fitted Rick olivers road needle kit and used 0.5mm shims.CMSMJ1 wrote:Have you messed about with the carb slides or needles?
- banoffee
depends on which jets. you might also find this useful for general troubleshooting of jetting...matt_nc30 wrote:Neosophist wrote:Sorry, but wouldnt blocked jets affect top end?
http://oldskoolsuzuki.info/perversepoli ... eshoot.pdf" onclick="window.open(this.href);return false;
I agree.
It might be just 1 hole in one emulsion tube thats blocked if the cause does turn out to be dirt / fuel contamination.
Bike would feel normal apart from being a bit lumpy.
Just an idea :-)
If all else fails and you can't find the problem you could consider getting it dyno'd, the fuel / air graph will give you an insight to how its running and if your problems are liekly caused by rich / lean :)
Just an idea :-)
matt_nc30
thanks for the guide banoffee
and thanks for the advice neo, i will clean the carbs and see how it does.
Im definately wouldnt mind getting it dynoed though, i would like to see how much power she has left after all these years.
Would a air/fuel ratio graph come from just doing a power run? I have not taken a bike to a dyno before.
Thanks all
Thanks all
Ask your dyno operator.. they should do a fuel / air graph as part of the run :-)
Mine was running wel (55bhp) but the fuel / air was way too rich.. i've leaned her out quite a bit and done the clutch springs etc and it feel twice as powerful, can't wait to put it through a dyno again
