Page 2 of 3
Re: Injector to NC29
Posted: Mon Jan 25, 2010 11:03 pm
by racesupplies
Do you need port centres?
Posted: Tue Jan 26, 2010 12:13 pm
by PARUS
racesupplies wrote:Do you need port centres?
Yes, if you can.
Posted: Tue Jan 26, 2010 12:41 pm
by racesupplies
OK from left to right centres 71mm middle 107mm then 71mm.Centres from 1-4, 248mm.
Posted: Sun May 30, 2010 10:04 pm
by PARUS
Looks like cbr600rr 2007 too bihe - 38mm
CBR600RR 2005 Throttle Body Venturi Size - 40mm
Still looking for 32mm venturi size.
Individual from JERNEY is good
http://www.jenvey.co.uk/~WhyJDL.htm, but too expensive for me include other required modifications.
Posted: Sun May 30, 2010 10:54 pm
by Cammo
Parus, why not just use the nc29 carbs, just blank off the passages you don't need and mount some injectors to it??
For the basics all you really need is a throttle valve and a suitable place to mount the injector. The rest of the system should be no problems.
Posted: Mon May 31, 2010 4:03 am
by Cammo
How about some tb's off a suzuki GSR400? Gpoing cheap on yahoo Japan:
http://page15.auctions.yahoo.co.jp/jp/a ... t164526925
Posted: Mon May 31, 2010 8:29 am
by matt69
The latest CB400sf is injected and learner legal in Australia, which means wait a while and I am sure a set of injectors and ignition for it will come up for sale.
Apparently it is called an NC42 or Revo
Matt
Posted: Mon May 31, 2010 12:13 pm
by PARUS
Cammo wrote:Parus, why not just use the nc29 carbs, just blank off the passages you don't need and mount some injectors to it??
The appropriate throttle bodies is the half of problem - camshaft position sensor also need to be mounted.
Posted: Mon May 31, 2010 12:14 pm
by PARUS
Thank for the advice - it should be good idea to use GSR400 throttle bodies.
Posted: Mon May 31, 2010 12:16 pm
by PARUS
matt69 wrote:The latest CB400sf is injected and learner legal in Australia, which means wait a while and I am sure a set of injectors and ignition for it will come up for sale. Apparently it is called an NC42 or Revo
Matt
I'm not going to do it this year - as far as I'm not going to sell my 400cc for ever - I can wait, but I don't see cb400sf very popular and I don't think we can expect some of them will broken nearest feature. So, for not just collect information which donor throttle bodies I can use for conversion.
