Page 2 of 2
Re: whats it worth? NC23 with dead engine
Posted: Mon Jan 18, 2010 12:23 pm
by Matchlessman
Hi,
You really would be best to get it running etc, it looks a cracking bike! And in the best colourscheme. :)
If you do end up breaking it, can i be considered for the fairing infills. - They would be perfect for mine.
Posted: Mon Jan 18, 2010 4:57 pm
by Wozza
Tbh breaking it would probably get you more money than selling it as a non-runner if you had the patience.
Posted: Wed Jan 20, 2010 5:32 pm
by Superjack44
Different bike but nc23 engine mine would not start after only three weeks or so what I did in the end was to remove the plugs and heat them on a stove then whip them in quick like and away she went
Posted: Sun Jan 31, 2010 12:04 am
by BillingCBR
Are you about tomorrow? (sunday) Give me a post code and I can drop in after I fix my CG. I'm only from Thetford, about 40 miles from you, I'll bring my haynes manual and a few tools and we can set to work on it. Would be no trouble at all mate, I'll be about after 11ish and can be there til 4.30ish
I have a set of spare NGK plugs in my shed, I'll bring them just in case yours have failed
Posted: Thu Mar 11, 2010 1:17 pm
by sh4d0w0lf
News update: i've got a week off next week and have got permission to use the inlaws guarage to rebuild the engine...
List of things to do includes:
Double checking the timing... (might be the reason why she wont start?).
Removing the sealant between the two crank case halves (i have a bad feeling that it got into the grooves where the oil flows..
Double checking that the gearbox was set up correctly..
And finally i've got a bolt hole to re tap where the casing bolts on..
After that its gonna be a case of putting it back togeather and fitting it back into the bike ect (
I'll try to keep you all updated with my progress.
