Wanted 3TJ top (headlight) fairing
Re: Wanted 3TJ top (headlight) fairing
mirror winkers would be good! shouldnt be too hard to add mounts, its just a threaded bar with smooth rear end inserted into the plastic 'lump' (had to cut mine off the crash damaged one i had!) that go into the 4 mounting points. unfortunately the bottom two were missing or i'd send em for you to stick on! maybe someone has a damaged top you could get em off, make your life easier!
I bought a front subframe fot £20 delivered, so can hang the headlight off that.
And my race fairing is 3-piece and looks to use original sides & V (it looks like a home made bodge up but it works).
At the end of the day I could run it without top/side plastics or screen and it would have all the lights. I do have some bits of the top fairing that got smashed plus the screen was undamaged, so maybe some fibreglass work and I could have something useable if not pretty.
I think when it's MOT expires at the end of August I won't renew it until at least next year as I'll track it for the cheap winter days like this year.
That sounds like what I need ... anybody out there with one let me know please :)Taggy wrote:mirror winkers would be good! shouldnt be too hard to add mounts, its just a threaded bar with smooth rear end inserted into the plastic 'lump' (had to cut mine off the crash damaged one i had!) that go into the 4 mounting points. unfortunately the bottom two were missing or i'd send em for you to stick on! maybe someone has a damaged top you could get em off, make your life easier!
