Oil cooler help for NC30
fastdruid
Re: Oil cooler help for NC30
The pump change is more for having the 'UK' method which diverts (some) oil through the cooler and (apart from the pump itself) involves different piping internally. As long as your pump is decent and your big end clearances[1] ok you shouldn't have a problem.
Druid
[1] Amongst others but they seem to suffer first.
Druid
rs2fifty
- Bike owned: NC 23, RGV, RS, RD
Thanks fastdruid
I wouldn't bother with drilling the block / fitting the cooler.. your going to need new gaskets etc, it's going to cost too much.
Just go with the water cooler plate if you need one.
Or... bolt a 24 engine in there
rs2fifty
Hi neosophist
If i think what your talking about is something that ive seen in one of the forum threads then i cant keep my fan as well, which is something i want to do. I know it may seem a bit overkill with some of the bits i have on the bike but it is going to be worked quite hard and a bit of extra oil with a cooler isnt going to do it any harm i wouldnt think.
The sandwhich plate and stubby filter sounds like what im looking for, if it fits
cheers
cheers
Howdo.. Just to advise that with the sandwich plate and std filter you cannot fit a fan at all - it all fits in but I had to dink the top of the filter to stop it touching the rads.so the short filter is essential. You might even get shorter filters that the Yamahah one, I don't know.
May get chance to nip up the garage and take some pics/measurements later on..
- superlite
- Bike owned: TLS, LB80 x 2
I don't want to add a negative tone to this thread......but I will anyway.
If you don't have some serious engine mods going on then there isn't really any point going to all the effort. And by serious mods, I'm talking heads, big bore, etc.
I run standard rads and a full HRC carb set-up (standard engine, no fan). I race at the peak of the Australian Summer (40+ degrees) and I don't have any overheating problems aside from when I slow down to pit. I haven't had any probs on a road NC30 either - they run fairly hot standard - but I can appreciate that you may want a fan for traffic.
Perhaps your circumstances warrant it, but personally I'd be spending my hard earned cash elsewhere.
'Take it to the Back'
rs2fifty
Thanks superlite, your point is well made and sensible, but you know when you just get something in your head and no matter whats said you are forever trying to justify it to yourself, well for me this is one of them. I'm at a point where i cant do much else to my other bikes and ive had this in mind for the vfr for a while.
Thanks CMSMJ1, i will be very interested to hear what measurements you find to see if im likely to have the clearance for the mocal sandwhich plate, stubby filter and fan
Right on..
The stubby is 52mm and the std is 70mm - or thereabouts. I reckon you will struggle to run a fan with the Mocal but there are probably slimmer sandwich plates...but I never found one
@ Superlite - I hear you. I fitted mine just because I had the inclination. When I took the no9 to Germany it still boiled itself off the gauge and needed dowsing in water from a local village fountain..saying that, my rads were fecked. I now have a recored lower rad and all is peachy for my temps. Not ran a fan for several years and apart from the Germany incident I don't miss it. The ambient was approx 35 deg and we stopped for some villages....instant roistering..!!
The oil rad I have is large - maybe 9-11 rows and is stamped as KTM. I'll be changing this for a smaller ad that is more in the air flow - poss under the pillion seat in a ducted flow. We'll see...
rs2fifty
Thanks CMSMJ1, I will start hunting for a slim sandwich plate
Why not move the fan to the top rad like where it is on the NC24?rs2fifty wrote:Thanks CMSMJ1, I will start hunting for a slim sandwich plate
