Colortune from Morgan, anyone used this for an RVF?
Re: Colortune from Morgan, anyone used this for an RVF?
It will do!!tomski wrote:OhNeosophist wrote:you can build one using a standard narrowband lambda which isnt' very accurate.. it'll just tell you if it's rich or lean.. but the response time / accuracy isn't very quick.
if you want to build a decent sensor you'll need a 5 wire wide-band lambda sensor which are £60.00 just for the sensor.. then they need fancy electronics to control.![]()
I guess I'll have to look into this in more detail if I'm to pursue it then. It could well end up matching or exceeding the cost of a dedicated emissions analyser.
Thanks for the heads up Neo.
http://wbo2.com/" onclick="window.open(this.href);return false;
Check out there, they supply a lot of DIY kit stuff for Lambda stuff.
The 5 wire wideband (that can be used for fine tuning of mixture) needs a dedicated cpu to control it as the heating element etc is very delicate and it needs to be controlled properly else it'll die.
You can make a simple lambda thing to say rich / lean using some LEDS and a £1 chip, but it's not very precise.
WB02 do some very high quality wideband gear, and even a moto specific version (small size). Looking to get one soon that has data logging abilities.Neosophist wrote: http://wbo2.com/" onclick="window.open(this.href);return false;
If you don't need or want logging ability then there are cheaper options:
http://www.jaycar.com.au/productView.as ... rm=KEYWORD" onclick="window.open(this.href);return false;
Use above with this:
