smaller sprocket set
viper_biker
Re: smaller sprocket set
It's to do with the angle of the chain. Might only be a few mm, but apparently it makes a difference.banoffee wrote:interesting. the one it replaced (i.e. was on the bike when I got it) was the same way round. will have a look, cheers.viper_biker wrote:Banoffee, that sprocket is on back-to-front. The step should be pointing towards the wheel, not away from it.
mick.mh2racing
Definitely 14/44, cos I don't want to travel more than a ton anyway.
How hard can it be?
- royster81
rode 14/43 for about 90miles and the accelleration was brilliant but high revs on open roads made me swap to 15/43.mick.mh2racing wrote:Definitely 14/44, cos I don't want to travel more than a ton anyway.
never tried 14/40 but i have a 14 and a 42 and 43 so i have a few options
vr6will
Can you buy chain and sprocket sets with -1 front tooth? if so where?
What number of teeth front and rear does an RVF400 NC35 have as standard?
- Polisher
- Bike owned: z1000a1h, vfr800vtec, nc30,
Banoffee, Viper is right, the step should be facing the wheel. Looks like a Rentha HA sprocket like I have and the writing should always face out. Again Viper is correct and it may throw your chain alignment out slightly
- Polisher
VR6will - I always get my sprockets from B&C Express in Lincoln - always use Renthals personally. They are good value and very helpfull
- Speedy
- Bike owned: RVF400RR, ER6n
15F 38R, 525 pitch.vr6will wrote:Can you buy chain and sprocket sets with -1 front tooth? if so where?
B&C express seem to be a popular choice and are quite helpful: http://www.bandcexpress.co.uk" onclick="window.open(this.href);return false;
Give them a call and they'll tell you the correct number of chain links for the sprockets/bike you'll use.
A 520 pitch chain&sprox (lighter) is a good mod too!
vr6will
Been using the search - the 14t appears to be a popular conversion, as does the 520 pitch conversion, and while I'm there changing the chain I might aswell do it.
I'll give bandcexpress a call in the morning!
- Matchlessman
-1 on the front.
Ive got a +2 on the back as well and its a bit too much if you want decent motorway cruising. I came back from a bike rally in france in 6th at over 13,000 revs for most of the time, just trying to stay with my mates. i felt very guilty about thrashing the engine that much for so long. That was on a NC23 though, not sure if the viffer engine would handle that sort of abuse.
vr6will
whats the difference in changing just front sprocket compared to just the rear?
I.e. why would you leave the front standard and go up a tooth or two on the back? Or is that not the done thing?
