Front calipers vfr 400
rider4life
Bike owned: Vfr 400 nc30
Post by rider4life »
Do calipers from vtr 1000 sp2 fit straight on the vfr with no mods ?
neurosyndrome
Re: Front calipers vfr 400
Post by neurosyndrome »
I don't think so...
Are they the same than SP1's ??
You'll need a mounting kit. Rick Oliver sells some ;)
http://www.rvf.dk/rickoliver/" onclick="window.open(this.href);return false;
I quote : "Brake caliper mounting kits - NC30 forks/SP1(CBR600RR/Fireblade) calipers"
Cheers,
DanHam
Post by DanHam »
I like the sound of this, bit of a noobish Q but will they work with my VFR Galfer discs?
Post by Neosophist »
DanHam wrote:I like the sound of this, bit of a noobish Q but will they work with my VFR Galfer discs?
Damn been answered.
I can't recall but are the SP2 calipers different to the SP1?
Either way you'll need brackets making up. If they are the same mounting as the SP1 then
Fortuantly the SP1 CBR600RR calipers have adapters made up for them by Mr Rick O.
They just move the caliper to the point where it can be mounted ;)
You can use your standard disc.
Cammo
Post by Cammo »
SP1 and SP2 calipers are the same, and same fitment as 2003-4 cbr600rr.
I recently got some caliper adapters from Rick O, very impressed with the machining quality as usual.
micpec
Post by micpec »
There is also a possibility to fit Brembo's 65mm calipers on the NC30 (using alloy brackets).
If interested, I do have a complete Brembo set that will be for sale soon.
pugparcels
Post by pugparcels »
maybe worth noting, if you cahneg the calipers to sp1/fireblade calipers with the rick oliver brackets your existing brake hoses wont be long enough.
