Chain Lube That Doesn't Paint The Rear Wheel!
rich1988
Re: Chain Lube That Doesn't Paint The Rear Wheel!
done that it still covers my wheel in lube!, I use castrol chain wax and it absolutley covers the wheel if Im not very careful
Spike16
+1 with wurth's
Iv tried Muc off before and that wasnt bad but did leave a bit of crap on the wheel but not alot tbh, then when I ran out of both I used some Holts stuff, OMG thats soo crap, went for about a 20 mile ride and the rim and swinger were black! then got the wurth stuff and never looked back
Lope
I usually alternate petrol and water to wipe the crap off my rims, nothing has worked easier so far.
Anyone thought of making a bottom chain guard?
Kerosene / Parafin is the best stuff for cleaning the chain with, and the wheels. It doesn't displace as much grease from behind the o-rings as WD40 etc do.
I usually use gearbox oil on an X/O ringed chain, just clean the chain and apply a light film to stop surface rust. Dont' have any fling off.
I've got a can of Putoline chain wax that you boil the chain in (non ringed chains) that I use for tradition chains.. fantastic stuff and no flingoff either... bit more work taking the chain off but worth it imo. Will be using a non-ringed chain next time again.
- banoffee
Lope wrote:Anyone thought of making a bottom chain guard?
banoffee wrote:Lope wrote:Anyone thought of making a bottom chain guard?
But if these were brought back all the companies that sell you cleaning products would loose a lot of monies
- alexwitham
at the moment im using the last of my Castrol 'dry' chain wax, its ok but it don't 'alf leave a load of spray on my whites!
I think im going to go for a tin of 'wurth' as alot of you guys seem to give it a thumbs up!
as for the C90 look.....
fixer
- Bike owned: nc30/bsab25
Try S DOC 100 white chain spray available from hein gericke.
F I X E R
rich1988
ohh white spray what a good idea !:Pfixer wrote:Try S DOC 100 white chain spray available from hein gericke.
