My NC30 Dyno Results.
Re: My NC30 Dyno Results.
91RON unleaded.G-MAN wrote:Just another silly questionbut wen Honda measured it back in the day what RON Fuel did they use and was it really that efficient in today's standards?
				G-MAN
So then we can't really go on Honda's numbers either Stickshift or what do you think?
Honda's figure is as accurate as they want to report it.G-MAN wrote:So then we can't really go on Honda's numbers either Stickshift or what do you think?
Putting anything higher in than 91ron won't increase performance unless you've raised the compression or advanced the ignition to the point that it's detonating on 91ron.
				sorbe88
 - One Hit Wonder
Just a quick note from an engineer...
BHP is BRAKE horse power, the brake part refers to being at the crank;
HP is just horse power, ie referring to that produced at the rear wheel.
So, rear wheel power is stated in HP, while engine power is stated in BHP.
Hope that helps!
Hope that helps!
- alexwitham
I use shell VPOWER 1 in 3 tank fulls, ive no idea why, but ive done it with all my bikes. I think its all personal preference.Putting anything higher in than 91ron won't increase performance
